My parents have been holding onto this piece of drift wood for ~20 years with the intent of turning it into a lamp base. As you can see from the pictures it doesn't sit flat and more importantly, needs a bore down the center for a threaded rod. I have some ideas about how to do these things but would appreciate input from others.
For the base, my thought is to rough trim the "low" spots and sand things down to get a stable base. Getting the main trunk vertical will be a test and repeat exercise unless others have a better idea.
More problematic is how to drill a straight 7/16" hole down through the center of the trunk. I have a large capacity drill press and lots of normal length bits of various types.
How would you do this? When I was a kid my father used to run the White Furniture factories in Mebane and Hillsborough, so he's no slouch but has never had the shop equipment to tackle this project. I'd like to give it to him as a 70th birthday present. Any suggestions will be greatly appreciated.
