I use the scary sharp method of sharpening, and although I am getting decent results, I am far from splitting hairs. Admittedly, I am not using very good chisels, but I still feel that I am doing something wrong. I use a thick piece of glass, and spray glue strips of sandpaper in grits from 120 to 2000. I also use a veritas honing jig. My big questions are these:
when sharpening, do you only push the chisels, only pull them, or do some sort of combination of the 2?
should you go through all the grades with the back of the chisel before honing the bevel, or lap the back on one grade then do the bevel on that same grade, then move up to the next grit?
I have read a ton of things on the net about sharpening, but none of them have addressed these (simple) questions. Also, I have never seen a burr form on the edge of the chisel, so that's probably good evidence that I am doing something wrong. Any info would help!
