Hey guys,
I decided to get my tools up off the ground after seeing a design made from 2x4 and decided to make it out of 2x2 tubing instead with internal plumbing for dust collection going to an port on the back with blast gates between each tool. My thoughts on this design was being able to use the 55" table top as an outfeed for table saw and built-in router table. The end near the router will have double slotted standards so I could have an adjustable shelf to place different tools on depending on height needed, this way my planner/bandsaw could also use the tabletop as an outfeed. On the back side I was debating about the same adjustable shelf for a miter saw station or using fliup shelf brackets. The bottom drawer would be storage for my tracksaw rails and wood clamps, make the space below the router strickly for router bits, wrenches and secondary router.
I need some input on my design to make sure I am not forgetting something important, lastly should I go router lift or Triton? Currently I only own one cordless rigid router and was leaning towards a Jessem lift and bosch 1617 unless the Rigid 2202 router is better?
