Room temperature for cured resins isn't a big deal. Make sure your carbide tip is sharp, if not give it a quarter turn to reveal a sharp face. Keep a toothbrush with your lathe for resin, it is the perfect brush for getting those resin strings off the lathe and out of the way so you can see. The toothbrush works better while the lathe is running.
Negative rake cutter, that is a bit loaded. The negative rake carbides are great for finishing your piece as you're taking off the last amounts for the final look. I do not recommend them for shaping as that is not what they are designed for. Negative rakes work the same as regular carbide tips, they just offer cleaner finishing cuts like a steel scraper compared to a cutting gouge. Yes, negative rake can be used for shaping but doesn't work as well in that capacity.
As mentioned, higher speed for turning resins. 1000 is a good start but not high enough for large items so if you're getting those vibrations it is because the piece is out of center or the lathe isn't stable. Keep the 1000 until the piece if evened out and then turn it up more. Also, clamp your lathe down as tightly as you can to reduce bouncing that comes with your moving it around and not being on a permanent, heavy base. For mid sized lathes its easy to bog the motor down with heavy cuts so just take smaller, consistent cuts to prevent that. The piece will take a little longer to finish but that is reality of a small motor on a lathe.
Regular carbides are a better option to use for shaping and removing material. Make sure you have the banjo/tool rest set to the right height so your tool is centered on the piece when you go to cut. With carbide tools you want the tool to be flat on the tool rest to get cleaner cuts, not angled left/right or up/down. You are using the sharp edge to cut and the edge is flat so changing the angle on it can reduce effectiveness because you're now using less of that sharp edge. Start with smaller cuts, don't get too aggressive up front. Let the tool do the work, no need to force it because that is one thing that leads to chipping.
Hollowing, take your time. It is easy to get a catch inside the vessel which can cause it to come out of center or fly off the lathe. Be patient, don't rush.
If you have any questions feel free to shoot me a PM and I will help as best as I can.
