Hi. I make simple things like my work tables and chicken house, but am not an accomplished woodworker by any means. I have the chance to paint an exterior mural on a 4 ft diameter round kiosk and plan to use a plywood backing, but I need to bend the plywood. The ply I have is nominal 1/4" (actually closer to 3/8") and the two panels will be 6 1/2 feet long. We plan to wet the panels with hot water and bungee them to the surface, dousing with hot/warm water as we go until dry. I thought I'd make a frame to hold the panels in shape as I paint. Does this sound as if it would work?
Kerfing such a thin board seemed like it might not hold. The surface may get a lot of wear, as it's atop a bulletin board at the downtown library. I imagined a flyer being stapled, the kerf popping and the youngster doing the stapling flying into the street.
I'd appreciate ANY suggestions at all. Thanks so much.
