Need CNC help
Willemjm
Willem
I need a clover pattern and a groove line cut in 1/4” Maple Ply MDF core for two doors before I glue-up as per pic below.
Will pay.
kserdar
Are you sure that wasn't cut with a laser?
What size are the panels?
What size router bit is needed to make the clover? or is it V-carved?
tri4sale
Daniel
This tips look awfully small, and more pointed then the bit on a CNC would accomplish, that looks more like a scroll saw cut then a CNC. I've got a CNC but not sure I could produce that fine a point.
ScottM
Also thinking scroll saw. How big is the upper panel? Are the doors already assembled?
blackhawk
Brad
You can get to a fine point like that if you use a 30° V cutter. You can do a V-carve strategy with the 30° and then pocket out the main part with a 1/4" or 1/8" endmill. If you didn't want the 30° angle along the edges, you can fudge the lines and just have the 30° V cutter just cut in the sharp areas and then make those spots vertical with a chisel. This is what I do to clean up the corners of a rectangular mortise joint when I cut it on the CNC.
I could do this for you but I am in Virginia.
Willemjm
Willem
Thanks, that’s quite a drive for me.
If anyone closer can do that with a laser it will also work. I have not made the doors yet, and they will be painted once done.
tri4sale
Daniel
hmm, didn't think of trying it w/ a 30V cutter, don't think I have that size or I'd give it a try and see how it looks.
SJWiehe
I can cut it. I have a 4’x8’ cnc. I am in Florida until late next week but would be happy to cut it when I’m back. My shop is in North Raleigh just south of us 98.
kserdar
I have both CNC and laser cutter. The laser has a much smaller working area.
Thus, back to one of my first questions - What size is the "clover" panel?
And how soon do you need it?
Willemjm
Willem
Thanks everyone for the great response!!!
Think I will give this a shot by hand with a router, template and some hand work, trying a sample first. If I do not succeed, will reach out for help.
Skymaster
Jack
brad does all the emblems for our urns. I have a laser but dont know how to use it, bought it to engrave the urns rather than driving back and forth to morrisville. 5 watts.
Willemjm
Willem
Thanks to all for reaching out, much appreciated. I ended up doing these the old fashioned way, by hand and they came out nice and clean.
One thing I seem to never learn is not to procrastinate and think about how to do stuff, when I am not in the shop. Once in the shop, it always seems to just happen.
