If you have it commercially stripped, don't let them dip it. My Dad had my Grandparent's dining room table and the glued up legs -- were no longer glued. Also, if the graying at the bottom of the door remains after the stripping, you may want to consider bleaching the wood. Not my first choice, but have had to bleach a veneered desktop to remove another's attempt at finishing. Worked pretty good -- but its caustic so wear gloves and don't do it in a room that is not well ventilated. Final word -- after you strip, look at the wood after you wipe mineral oil over it and look at the grain pattern. If you like what you see and really want it to pop, then consider sealing the wood and using a tinted wood filler.
