All,
I had planned on making an end table vise. Originally, I had planned on making the screws, but after seeing the post on making a moxon vise using the Walmart dumbell screws, I thought ........ AHA !
So, this was a result of that postings hats off to our group for the inspiration and tip. I have 15 bucks in this ... all the wood I had.
Since the table is 3" thick I drilled a 1-1/16" hole into the side 12" deep to receive the threaded rod. Then I routed out and mortised in the nut on the table board that is attached. I left it kinda loose to allow it to move to facilitate easier turning and prevent any possible binding. I screwed this into the table end.
Then tapped into the end of the threaded rod a couple of screws w/ nuts on them so I could use the screw in the rod with the cordless drill when not in use. I sandwiched the other nut between the hex nut I made and glued it up. Wood used ---- African Teak, Honduran Mahogany, Maple, Paduk, Sapele, White Oak and Red Oak. The tightening nuts are 2-1/2" wide. This thing REALLY works well.
Thanks, NCWW and especially the guy who clued us in on the 6.88 cent dumbbell screw. My table is now complete, that was the only thing I had not done.
Thanks again .............
