My take on a ripping/tapering sled for the table saw
Jack A.
Jack
I have a piece of plywood that I have been using for a ripping sled for a while. This is mostly used to rip a straight edge on rough-cut lumber. Previously I would use double-stick tape or screws to hold the work piece to the board, but I finally decided to make it permanent.
I considered using a T-track, but the track I have requires a 1/2" deep groove, and I didn't like how little wood would be left after that. Plus you'd really need to add a couple tracks to handle both wide and narrow boards. I eventually came up with the idea to cut upside-down T-slots in the board, and run them across the board rather than along it. I figure this leaves the most meat and provides a lot of flexibility.
I started by drilling a 5/8" hole all the way through the board. This acts as a keyhole so you can insert a T-bolt from the top. It also provides a good starting point for cutting the T-slot. A router jig keeps everything straight and aligned while the slots are cut.
The T-bolts I have are in 1/4" and 5/16" shank diameters, and the head in both cases is around 1/2" wide. So I cut the narrow part of the T-slot to 5/16" and the wide part to 9/16". This is wide enough so the bolt slides easily enough, but narrow enough so it engages the head while tightening.
I'll need to relieve the shoulders of the keyholes a little to allow a 5/16" bolt to slip in without lifting the board, but a 1/4" bolt slips right in.
So the bottom looks like this with all the slots cut.
And here it is with a board attached, ready for ripping.
BobbyB
Bob
Jack,
I see you have a Laguna tablesaw. What model do you have and are you happy with it if you don't mine me asking?
Jack A.
Jack
It's the F2 110V. I'm mostly happy with it. A lot of the reviews I watched/read before buying raved over the fence, but if I knew then what I know now, I'd have gone with something with a Biesemeyer style fence instead. The built-in wheels were another selling point, and they have proven quite useful while the shop's in flux.
