I bought a lathe a few weeks ago and had not used it as I’d been looking for some cutting tools to get started. Last weekend, I visited an antique shop while visiting family in western NC, and stumbled across a set of Disston turning tools for a great price.
While at home, I visited Klingspor’s Hickory location and purchased a set of centers for the machine so I could get to turning. I have a lot of experience turning metal, but none with wood, so I consumed a totally reasonable amount of Paul Sellers and Frank Howarth videos before getting into it.
I sectioned out a piece of rock maple from a scrap of a finger-jointed butcher block workbench top, and planed off the corners, then got into feeling out the tools.
I set out to make a replacement chisel handle for a cheap Jorgensen chisel I use to remove bark and glue. The plastic handle from this chisel had loosed up a while back, and I figured I’d try and get a bit of extra life out of it.
After turning the shape to suit what I thought might make a nice fit in the hand, I cut a copper pipe coupling in half to make the ferrule, and polished it in-situ on the lathe.
I drilled, and mortised a hole for the tang, then burned it in. Unfortunately I set the tang a bit early without having removed quite enough waste, so the shoulder of the tang has not fully bottomed out in the handle. This isn’t such a big deal, because like I said, this is a junk chisel I reserve for tasks I don't want to put my nice Japanese chisels through. If it fails, I know what to do better next time.
This was a joy for a first project. I have quite a few spindle turning projects lined up, so I’d love to hear what sharpening setups folks here recommend. I have a 3600 rpm Baldor stand grinder that I’d prefer to use, but I’m seeing quite a few folks online recommend slow speed grinders. Any advice or turning tips to demystify things will be greatly appreciated.
