So I pressed my first tabletop tonight. Everything went well for the most part. My main question is in regards to glue squeeze out. My set-up is melamine bottom platen, veneered tabletop then breather mesh. After pressing for about an hour I pulled the panel and all looks pretty good except there is glue squeeze out all over the veneer faces (face/backer) as it went right through the veneers. My question is, should I try and get most of this off now while it is still wet or let it dry and sand it off? Also there is glue inside the bag and all over the breather mesh. What is the best way to deal with this? Did I miss something or is this all normal to vacuum press work?
Thanks!
Thanks!
