More Cherry Burl
Dee2
Gene
Here's the next cherry burl. This one finished out about 15" in diameter. I got two cores out of it with the McNaughton. It was much easier to core than I expected. The cores were taken inside the big bark inclusion but it was close on the larger core. I'll post photos later of the cores when I get to work on them.
I kept the wall thickness of this bowl at ~3/4" as I was concerned about the structural integrity. I did wrap the bowl in reinforced tape while turning the inside. Sanded to 400 grit.
Need to decide on a finish. Suggestions?
FWIW, some of the bark inclusion is really sap jelly. This burl had major sap jelly. The burl was also wet and made a mess of tools and lathe while turning.
The figure in the bottom of the bowl carries over into both cores. They should turn out nice.
Here's a tease: I've got a 14" bowl from the other side of this burl (the burl wrapped the trunk) in the shavings pile along with a platter with outstanding figure. So more to come.
JonB
Jon
An oil finish would look really good on that burl, I use Minwax Teak oil (it has some UV inhibitors). I generally put on 3 good coats letting it soak in for 15 minutes each time and waiting 24 hours between coats. After that cures for at least a week you can buff with Tripoli and white diamond and you'll get a really nice soft luster without being too glossy.
Dee2
Gene
I was thinking tung oil. I have some 100% but may try some of the Minwax for the UV inhibitors.
gritz
Robert
Tung oil will significantly darken the wood over time. I use walnut oil to keep the just-finished natural look of the piece.
Mauser44
Nice.
I have used OB shine juice or bees was mixed with mineral oil on burls. I usually try to stabilize the blank prior to turning then use sanding sealer before the wax coat.
Btw. Do you have any cut offs from the burl ?
Dee2
Gene
Steve, Thank you.
John, The cut offs were minimal and what was saved is now pen blanks.
