Monday started off with a bang!
Dee2
Board of Directors, Secretary
Gene
Relatively new blade.
Seems the it was a 'cold' weld for about 60% of the length.
Wow, that disconcerting for sure.
bainin
bainin
I've had several Timberwolf blades do that as well. Upon sending them a pic of the break at weld, they replaced the blade for free...I guess thats the upside ?
creasman
The wide blades make great scratch stocks and scrapers. You probably have a lifetime supply now.
tvrgeek
what size band saw? What is the blade thickness? I ask as there has been some discussion of the limits on a mere 14 inch saw and the wide blades.
Welds will be more brittle than the band. I wonder if brazing is a better technology?
If they are annealed correctly they won't be a problem.
Dee2
Gene
Some answers.
I bought this blade from the old Woodcraft saw blades. Now under new management and new name.
The blade is 1".
The bandsaw is 18".
I'll have to measure the thickness.
It was a startle, but not in a 'soiling' kind of way. Maybe my startle factor is subdued compared to others.
When it broke, I knew immediately what had happened. The blade had been clicking the last couple of uses. I did inspect the blade before starting to prep some turning stock but didn't find the source of clicking. In the future when I hear that sound I'll check the weld more specifically.
Outside of 3-4 kinks, I have 113" of scratch stocks and scrapers. In fact, my thought was parting tools. I use a modified 1" hacksaw blade currently. I just have to figure out, where/how to store the broken blade.
