I am having a problem with Franklins TiteBond III Glue, the glue lines seem to be raising up after drying and finishing the boards. TiteBond tech service tells me it is because the wood is shrinking around the joint as the moisture leaves the wood which I am having a hard time wrapping my head around. So I am l in the market for a good, not expensive, moisture meter so I can test the wood along the production process. Has anyone here had a good experience with a moisture meter and can someone recommend one that will not break the bank and stay accurate?
Thanks!
Thanks!
