% moister in wood for flooring
bman
barry
everybody says the the % should be 8-10 but the avg house in nc is going to run around 20 -30 % humidity do you need that level to make the wood workable or is that not realistic for the area ????:eusa_thin
jeff...
User not found
B4 just my understanding, so take it for what it's worth.
Solid wood floor is made out of kiln dried lumber. Good installers like to bring the flooring into the home where it will be installed a few weeks to a month before it's put down, so it will have time to acclimate to the environment of the house.
If the flooring is too dry in comparison to the house environment, it will swell and possibly buckle, I think this is why they leave such a wide gap along the walls. If the flooring is to wet then it will draw up and you'll have cracks showing in the T&G joints.
Acclimation is a good practice for any solid wood your going to use to build something out of for indoor use, especially furniture no matter how the wood has been dried.
Also wanted to add, QS lumber will draw up more along the thickness of the board and flat sawn will draw up more along the width of the board. Even though QS will make a more durable, attractive and stable floor, you'll pay big bucks for it. In compassion to flat sawn, QS takes longer to mill, produces more waste, takes longer to dry and is more difficult to machine. therefore not many people will mess with QS'ing. But all things considered QS is a better end product than flat sawn in almost every way.
Thanks
NCPete
Pete Davio
barry, as a former installer, I have a few questions for you:
how will you be finishing the floor??? what products?
what substrate will the floor be installed over? OSB, 3/4 ply? please say you are not putting this over a slab foundation.
How will you be installing the floor? I like staples myself, with some sneaky top nailing near the edges where the stapler won't go, but trim or brad nailer will fit, and some nails in the groove or tongue, depending on fit.
3-4 days is usually what we looked for, for acclimating the material to the house, tho' by accident of bad scheduling, sometimes it would be much more, sometimes less. I never had a call-back for hardwood floors for movement issues.
be aware that the material will try to twist, some of this can be taken care of with the BFH must flooring staplers are actuated with, but sometimes it must be addressed by a second set of hands and more tools, we would often use the Bessey - Pergo straps for situations like that, if we were trying to save a box, and there were several boards that had tension in them.
I am sure I had more questions than that a few minutes ago, but memory fails....
bman
bman
barry
yeah i know about the acclamation process. i will be making the flooring so i guess i will need kiln dried lumber .....you know where i can get some around here let' say around 800 bf when do you start to get a price brake on lumber ?????
jeff...
User not found
You may want to talk with Kyle, if he don't chime in here. I know he has a kiln and think he has moulding machine set up to make T&G flooring (though I could be wrong). Odds are you'll get a better product and price from him than from a BORG.
Thanks
bman
bman
barry
pete
will be using many coats of Polly
i will be on a ply wood sub floor (do i need to put down any rosen paper on the sub floor first)?
t- nail Thru the tongue
bought that shaper and i think i can make the material myself and save a ton of cash on materials i got plenty of time thats what i told the wife anyhow :-D
my main question is what raw stock do i need to start with
Kyle
Kyle Edwards
dont use a water base poly. if you have the ability to apply an aluminum oxide finish do so..
the question I would ask is what does the LOML wants not what you want otherwise look forward to many years remarks that may not be positive :)
Im going with a #1 common cherry for my floors and started running it last night. Finished width will be 6" face which means I start with a 7" board.
one more thing..it usually takes about a week or more to acclimate 10-12% wood to 6-7% air conditioned environment.
jeff...
User not found
Too bad hickory could not be used, man what a floor that would make (tough as nails) or can it be used?
bman
bman
barry
i though about that hickory that some nice looking stuff....wonder how it is to mill ?.....do you got any more of it
MC (moisture content) and RH (relative humidity) are very different things. They do have an effect on each other, but other than that they are different. The RH of a climate controled home is 50-60% but the MC of wood in that home could be in the 6-10% range. Other than I have no advice for HW flooring, other than it is better to buy it than make it if you value your time.
scsmith42
Scott Smith
Bman, a couple of comments;
I'll be glad to kiln dry the flooring for you, if you'd like. The price will depend upon the quantity, but for a 1K bd foot load I can probably get it down to .35 bd foot or so - which is pretty close to my cost.
If you can find someone with a solar kiln, they should be able to shoot you a much better price since they will not have the utility costs to factor in.
I would shoot for a final MC of around 7% - 8%, using a pin-type meter to measure the inside of the board.
I would recommend that you manufacture at least 15 - 20% more floor than you think that you'll need, to allow for losses, etc.
Re rosen paper - most top flooring installers recommend it. I used it under the 100 year old heart-pine flooring in my own home, and the squeaks are definitely minimized. Another option is to glue the bottomside of the seams (below the tongue) when you nail down the floor; if you do this it will remain extremely tight and rosen paper is not needed.
RE inside acclimation, longer is better. The upstairs of my house acclimated for 10 days before installation, and the downstairs for almost a month. Inside acclimation is especially important if you are using wide plank flooring!
You can use some of the excess flooring that you manufactured to make quarter-round trim to go between the flooring and the baseboard. Having the quarter round from the same material as the floor makes a pleasing transition.
To minimize degradation, in a perfect world the tree would be felled on day one, milled on day two, and go into the kiln on day 3. Any increases over this will result in more degradation.
Many folks will air-dry hardwoods until they are below 25% MC, and then kiln dry them the final amount. This will reduce your kiln costs, but increase degradation.
What species of wood are you planning to use?
bman
bman
barry
not sure yet i kinda like the hickory idea though .......thanks for the offer to dry it for me i may very well take you up on it new hill that is around sanford right..... how long is the drying process starting with 4/4 stock
cpowell
Chuck
Barry,
Here's a link to an Equilibrium Moisture Calculator or you can simply look it up in the chart below the calculator. 20 - 30 percent RH sounds low to me.
Wood Equilibrium Moisture Content Table And Calculator
Chuck
scsmith42
Scott Smith
Drying time depends upon the species and initial MC of the greenest lumber in the stack.
I may have missed it in the string, but what species are you working with, and do you know what the present MC is (or how long that it's been milled after felling)?
Thx.
NCPete
Pete Davio
back to second Scott's recommendation on the rosin paper, never did a hardwood floor without it. also, never did get to do one with material wider than the crap they were selling in the Borg's 8-9 years ago ---- 2.5 inches, IIRC, so we weren't concerned about longer times for acclimation
jeff...
User not found
Barry we literally thousands of BF in hickory logs, how much you need and at what length?
scsmith42
Scott Smith
Re interior MC levels in a modern, air conditioned home in NC, 40% - 50% is the assumption that I generally use.
Barry - to answer your earlier question New Hill is halfway betwen Apex and Sanford, off of US1.
jeff...
User not found
Scott I would like to talk with you, I had no idea your kiln was unoccupied and available, what's it's capacity?
bman
bman
barry
maybe a 1500 -2000 bf would do the job the wife does not conceptualize very well :BangHead: :BangHead: i would have to put a sample together for her to look at before we would be able to pull the trigger on that quantity.....i did get some from you in one of the lumber runs but that is still drying not sure ......came across some free logs big oaks about 3ft dia 4 logs 8-10 ft long .....hope to bring them to you and Ted soon :icon_thum :icon_thum
