Around 6 months or so ago I picked up the MLCS shaper cutters for plywood edgebanding. This set here.
Although this set is for a shaper, MLCS and others make sets for the router that work pretty much the same way. This set makes a tongue and groove, while others may just do a V cut.
I pulled them out and used them last week as I am building frameless kitchen cabinets for a friend. I had bought this set as I thought it would expedite and simplify the process of edgebanding the plywood.
I tried them out, and the slots cut into the plywood were less than clean. As the cutter makes the cut, the edges of the plywood are so sharp that they are extremely fragile and get crushed when pushing up against the fence. I went to the MLCS website, and low and behold, they now have a video on how to do this. Their solution is to double stick tape another piece of wood to the plywood to act as a fence for the bearing and fence to ride against. This procedure will and does work, but if you have a lot of edging to do is going to take a LOT of time.
My advice is to save your money and make t-molding using a grooving cutter and rabetting bits for your router table or shaper. You can make it fit perfectly and get it centered exactly. That is what I am doing with the cabinet job.:icon_thum
