Project w/ Pics Mirror Frame made from Scrap Wood and Milk Paint
karlkoch
Karl
When we remodeled our master bath I had a mirror company remove the 12' mirror and cut it into (2) pieces. They mounted one horizontal in the foyer and one vertical in the guest bedroom. I have finally made frames for them out of some (free) picture frame stock and scrap lumber. For the frame around the foyer mirror I wanted to echo the keystone block that is already present on both the inside and outside trim of the house. Also, I wanted the frame to look old and weathered like it was "found" in a barn or something. For this I distressed the finished frame, used multiple layers and colors of milk paint, and used a layer of "crackle" that makes the milk paint bubble and crack more in some areas. Then it was finished with a few coats of satin clear.
karlkoch
karlkoch
Karl
Thanks Richard. I did test pieces and tried to isolate different variables. But I still don't get consistent results with the milk paint crackle. The thickness of the paint, the thickness of the coat, and time between coats seems so critical and you don't know what you've got until it dries. But it's fun!
