Mini-Split unit kicked breaker
Main mother board is likely fried. Found a couple spots showing burns. Bummer. Searching for replacement.
That didn't happen out of a clear blue sky after 3 years of working fine. You should get a licensed electrician to diagnose what's causing the problem to begin with. Then contact the manufacturer (Pioner?) about the replacements needed.
gmakra
George
I have worked in HVAC for over 40 years. And I'm astounded at how many people can be armchair quarterbacks on troubleshooting. Do you think condensation might have had an effect on the motherboard. But since you're tripping the breaker I would suspect you have a ground fault at the compressor.
But we're not seeing what's going on or having a meter it's all just speculation.
