Just got a digital temp and humidity gauge for the shop. My Pioneer Mini-Split unit has a 'DRY' setting to dehumidify, but when I run it on that mode it will drop the temp into the low 60's! I haven't tried it often, once this winter and then again last week when the humidity seemed really high inside. I went out the next morning and the walk thru door was condensing water everywhere on the outside because it had cooled so much inside.
Is that normal for the dry setting? Does the temp gauge setting not generally work when on the dry mode?
Just curious. Humidity is running in the high 60's inside the shop. Building is very well insulated. I might go in/out 1-2x's a day, so shouldn't be letting in a lot of humidity.
Just curious how others work. I know mini splits aren't known for their humidity control.
