Here's an idle question: is it easy to MIG (actually flux-core wire-weld) common black pipe ? I assumed black-pipe was mild steel, but maybe its really more cast-iron-like ?
No, I don't plan on using this for gas-piping..I'm planning to make a large cross-dowel aka barrel nut by tack-welding a hex-nut into a section of black pipe. The cross-dowel will be used to repair my workbench - hence the post in this forum.
Related question: I was planning to run a threaded rod through the pipe and nut to keep everything in alignment while tacking. Will aluminum foil work to protect the threads from the welding slag ?
Thanks,
-Mark
Thanks,
-Mark
