Method To Hold Flute on Tailstock End
Flute Maker
I turn flutes in 3/4 , 7/8 and 1"...I rout two pieces and glue them together to achieve the bore....Then I put the hollow 1 1/2" blank onto a mandrel and turn it round....Sometimes I need to put it back into the lathe for just a little bit and and want another method beside the mandrel...Mandrel works great but I am going to use a jamb chuck on the headstock (just a block of wood on a faceplate with turned down steps) but I need something simple for tailstock end.....Also if I didnt rout quite deep enough and I am a little undersize I can split the thin flute when I put it back on the mandrel....So I just need something simple on the tailstock end to hold the flute for sanding , putting burnlines etc. I have begun boring some but still do some this way.... Thanks !!
CarvedTones
Andy
Mike,
If you use a steady center that is dead on center, you can use your live center even though the point isn't touching anything. The steady will make a mark on the outside surface though unless the steady has really soft wheels and you are turning hardwood. Even then, it will likely polish it a little.
Maybe something like this turned to fit your flute?
Makinsawdust
Robert
Wouldn't a cone center work? Because of it's shape it would hold the flute centered and not leave any damage. Here's a review of the Oneway cone system by NC WW'er Tom Hintz. Maybe it will give you some ideas.
Because the flute is thin walled the cone tends to push it apart. My first attempt was ruined in this manner, split it wide open. A snug fitting cylinder with a step flange works much better.
Makinsawdust
Robert
I was thinking more of using the reversed one. I don't how big the flutes are. The diameter may not be large enough to use the reverse one.
