Metal Corner Guards and Rain Diverters
manfre
Manfre
For my newly created shop, I need a rain diverter to go over the door because I cannot install gutters. I've also been trying to find an angled piece of weather proof metal (aluminum, diamon plate or stainless) to protect the edge of the plywood in the 5' door ways. The most likely thing to work for the doorways would be corner guards, but I have not been able to find any place local. Any help with finding either of these would be appreciated.
If all else fails, I can make both with a metal brake but I already have plenty of projects and would happily pay commercial prices.
Joe Scharle
I'm surprised you can't find a roof dam at lowes. They used to have them.
I'm having a problem visualizing your plywood edge guards. Does your plywood edges not butt against the door casing?
manfre
Manfre
The doorway threshold is the plywood resting on the floor joist. I want to protect the edge of the plywood from getting banged up as I move things in and out. The item I need is either sill nosing or 1"x1" to 3"x3" corner guards. In reality, any rust proof 1/16" to 1/8" thick, solid, 90 degree angled metal would suffice.
View image in gallery
Lowes and home depot don't show roof dams or rain diverters (they only show ones for downspouts) on their website and I wasn't able to find them in my endless wandering through the stores.
Skymaster
Jack
what I wound up doing was buying the 1/4" x 6" Azek type material at homedopey and bending matching aluminum trim coil to cover the exposed ply edge for my garage door
erasmussen
RAS
What I did on my 12 x 20 ( which looks like its from the same company as yours, just different roof style and different doors) was just build a small roof over the door, it keeps the rain from getting in.
Joe Scharle
It looks like drip edge would handle both of your needs. Along with a tube of Blackjack or whatever brand of roofing sealant Lowes carries.
Glennbear
Glenn
I recently made a trip to Home Depot to plan for a spring project and picked up a sheet in the roofing dept. showing the various metal profiles for roofing trim made by Amerimax. Here is a link to their website showing profiles that may be suitable above your door. I believe the drip edges were in stock:
http://www.amerimax.com/product-dripedge2.asp?iDripEdgeStyleId=8
As far as protecting the flooring edge I would recommend the flooring dept. I recall buying in the past various metal profiles used for transitions between different floor materials which would protect the raw plywood edge and are designed for foot traffic.:wsmile:
Wolfpacker
Brent
I've picked up scrap gutter stock from a nearby company and bent my own diverters in the past. I use black gutter stock and bend it by clamping in my workmate and hammering in to 90*. If you have access to a brake...no problem with longer sections.
Brent
