What I saw was wood grain outer with MDF core. I will see if I can grab a picture.
Avoid that at all cost. youll spend more time trying to seal the cut MDF stiles and rails. I would , however recommend using soft $$ (or hard $$$) maple instead of Poplar. The finish and stability is far superior to poplar. I have heard that HDF is good for machining and painting, but I have never found a source in the retail market locally to even try it. I believe it is what most cabinet companies use today, not MDF.Jumping in here re: MDF vs wood cabinet doors: I have been making my frames with 3/4" poplar and the flat panels from double clear coated 1/2" maple plywood. I actually sand the ply and rabbit the edges before spray painting (2 oil based primers and 2 semi gloss SW Emerald). However I'm wondering if I shouldn't simply be using MDF for both the frames and panels. My thinking is that I'd have less worry about the poplar frames bowing/twisting. Does anyone have an opinion on this?
Some of the really high end expensive cabinet manufacturers make their painted doors from HDF. The reason being that there is no seasonal expansion and shrinking, causing tiny paint separation lines where the cope and stick meets. The construction is same as five piece wooden doors. They are superior quality, we have never had an issue with themJumping in here re: MDF vs wood cabinet doors: I have been making my frames with 3/4" poplar and the flat panels from double clear coated 1/2" maple plywood. I actually sand the ply and rabbit the edges before spray painting (2 oil based primers and 2 semi gloss SW Emerald). However I'm wondering if I shouldn't simply be using MDF for both the frames and panels. My thinking is that I'd have less worry about the poplar frames bowing/twisting. Does anyone have an opinion on this?
I use 150 pre primer. The primer we use with a single coat fully fills the sanding marks. The primer is sanded with 120 drywall sanding blocks, which goes exceptionally fast and the top coat again seals any sanding block marks.I too sand the maple to 220 pre primer. The issue ive seen and its glaring , is seeing grain in poplar. where as the maple is glass smooth.
