Making a small draw knife
pop-pop
Man with many vises & whackers
This morning’s project was making this small drawknife for an upcoming project.
The tangs were cut from a used planer knife (about 15 mm. wide) freehand with an abrasive disk in an angle grinder.
Primary bezel ground to 25 degrees from the original 45 degrees. Ferrules are compression fitting nuts.
Practicing by rounding the end of a small square stick.
Wiley's Woodworks
Wiley
That is an ingenious way of repurposing a cutting tool that had outlived its usefulness in its original form. High quality cutting tool steel is a precious commodity. Well done Pop-Pop.
pop-pop
pop-pop
Thanks, Wiley. And I did not have to heat treat it!
DSWalker
Very nice. I'd be interested in seeing how you drilled the handles and secured the tang if you have any photos or can explain that process.
pop-pop
pop-pop
First step was chucking the stock using pen jaws and drill a shallow hole which provides a center for the next drill and a guide for the tenon.
Next drill the tang hole say 1/32” or so smaller than the tang.
I used a Bedan to form the tenon. Note that the edge of the Forstner bit hole is a guide for when to slow down and creep up on the final diameter.
The tangs were simply pounded on with a dead blow mallet. If they come loose with time, I will just epoxy them back on.
Hope this helps.
