Makers... Makers??
So I just got hooked on the Adam Savage "Tested" You Tube Channel and he had a guest on Laura Kampf, so on Adam's recommendation he suggested "Take a look at her channel"
I did and she had a video "Making a perfect table top" I thought well, that is curious, is this going to be another video of how you chuck a bit in a keyless chuck?!
NOPE! A VERY creative way of assembling a table top - you might like, you might not - what I like is the creativity!
mkepke
I have seen this technique before. My biggest critique would be there seem to be some pretty obvious glue lines (poor fitment), e.g. see 6:32+ in the video.
The bandsaw does not normally produce a a nice clean cut, and it shows here. The 'wavy' pattern she adds makes it pretty much impossible to clean up the edges after.
A better fit if you use say a router to cut the each edge of the adjacent board simultaneously.
-Mark
Raymond
Raymond
I remember watching some of her videos a couple of years ago and in most of her projects - she usually left what we would call 'imperfections' in most of her wooden items. Whether one sees a glue line or not is not the important point she stresses about - she looks for alternate methods. In this particular video, listen to her comments from about 8:20 through 8:42 - she is always looking for that organic appeal.
-Mark
Mark, I agree - but what I think is interesting the the alternative method as Raymond points out. so with knowledge and experience and the introduction of an alternate method, you ahve already cmoe up with a solution to a potential pitfall that we would not be happy with in our work! I saw the same thing and thought I would scrape or spoke shave that edge to see if I could get a better fit... I was just thinking about the abstract cutting boards, how do they get a good fit on the strips and pieces they glue together, maybe that is a method?
pcooper
Phillip Cooper
I saw a guy doing cutting boards like this and they were good from a distance, but not so good up close. I've used the router method a few times and ended up happy with the CNC cut. I don't think my by hand and eye method on a bandsaw would ever be good enough to satisfy my taste, and when I do have something that has less than perfect fit, most of my customers fuss, they don't like 'the makers hand' explanation on how there are imperfections to hand made items.
I have done this in the past. It is highly dependent on the accuracy and quality of the bandsaw. That saw she was using used today is still 3-4k it is a great saw industrial quality. I know from resawing wood how hard it is to keep a blade accurate enough to make matched saw joint by cutting through. The micro chatter in the blade is the issue. Not sure my 2 hp Jet BS could step up to this level of accuracy. But it is a very creative way to join wood.
