I would suggest some steps to determine where the loss of suction occurs: (1) disconnect the duct entering the DC and check for suction (as compared to the outermost connection); (2) Next, disconnect at the DC side of the "baffle" (which I assume is a Thein-type separator) and compare the suction again; (3) Next try it at the inlet side of the baffle and compare; (4) Check any of the flex hoses and machine ports for accumulated chips. As Michael suggested, perhaps your filter is clogged, which should be obvious if the first step above shows low suction. I have found several times that smaller capacity dust collectors like yours will really suffer suction losses from too much use of flexible duct (1 foot has the loss of nearly 10 feet of straight pipe), clogged ports or flex duct and clogged filters. And as Mike suggests, leaks can be a major demon as well.
HTH
