Be careful if you use phenolic. First, the phenolic sold by some of the WW retailers is not phenolic, it is ply with the top thinly coated/top ply layer
very lightly impregnated with epoxy- not nearly as durable as true phenolic. Second, real phenolic can create hazardous fumes if you cause it to smoke when machining it. True phenolic is made from many layers of epoxy/melamine, etc. soaked linen (or similar filler) cured under high pressure and temp. True phenolic may be hard to find and may be expensive. Its been many years since I bought any but
Aircraft Spruce and Specialty sells 3/4" for $8o. sq ft. !!!
Very true. The real stuff is VERY expensive. It will also dull your tool blades/bits quickly. Phenols are not user friendly.
