Looking for 4-pocket internal filter for JDS 750-ER air filtration unit
vbgregg
Gregg
Hi. I have a JDS 750-ER Air-Tech air filtration system that I bought about 21 years ago. I would like to replace the internal 4-pocket filter, but it looks like JDS is out of business. I googled and found other filters that claim to fit this unit, but they measure 12x24, which is too big. The JDS unit lists a nominal size of 12x24, but when I measured the opening, it is really half an inch shorter in both dimensions (about 11.4" by 23.4"). I bought a filter at Rockler in Cary, but it was indeed 12x24 and would not fit. Does anyone know where I can get a filter that will fit my JDS unit? Thanks in advance, Gregg
V
vbgregg
Gregg
Hi Matt. Thanks for the quick response and the link for the Wen filter. The listed measurements for the Wen filter are 23.5 by 11.88, so I'm not sure it will fit. Probably the 23.5 is OK, but the opening on the JDS is only 11.5 high (or a little less). So the 11.88 sounds a little too big. I just measured again and the opening for the JDS filter is 23.5" by 11.4" by 7/8". The current (original) filter is only 3/4" thick, so that is likely another problem, as the Wen filter is supposedly 1.25" thick.
Here is a thought -- the picture on the web site appears to show a metal frame with a border that looks like foam or plastic. If that border sticks out beyond the frame (as it looks in the photo), maybe I can remove or trim the border and make it fit, as long as the metal frame is no more than 23.5 by 11.4 by 0.75. Is there any chance you could measure your filter and see what the dimensions of the metal frame are, and whether you think the non-metal border could be trimmed to make it fit? Thanks a bunch.
Finally, I hate to replace the entire unit just because the filter size is non-standard, but if I go that route, I wondered how you like your Wen unit. What model do you have? I saw the Wen 3410, 3417, and AF1270 online. Would you recommend the Wen or are there other brands that you might prefer if doing it again?
Thank you very much. I really appreciate the help.
mdbuntyn
The metal frame is approximately 11 7/16" x 23 3/8" x 15/16"
Mark Fogleman
If you have one, would there be any way you could post a photo or scan of the operator's manual, please? I've used all my search skills and can't find one anywhere now that they have closed. My understanding is it's a single page. Thanks!
V
vbgregg
Gregg
Hi Mark. I am attaching scanned images of what I have, which I have labeled "manual", "brochure" and "filter_cleaning". I usually save almost everything, so I assume these are all that came with the unit. As you said, the documentation was pretty skimpy.
  • manual.pdf
  • brochure.pdf
  • filter_cleaning.pdf
Mark Fogleman
Thanks! I added them to the Resources
Canuck
I have had the same unit in my garage shop for about ~ 15 years now.
Did you see this offering on Amazon?
Amazon.com
V
vbgregg
Gregg
Hi Wayne. Thanks for the link. I've seen several on Amazon, but usually from vendors I've never heard of and with only a few ratings. Some of them gave both nominal and actual measurements, and they were too big. Have you used the one in your link? If so, I guess that means it fits, but if you have not used it, I'd like to know the exact measurements before ordering. Thanks, Gregg.
Canuck
No I have not used this one.
I may be in the same boat should I need to replace mine....just thought it may be a possibility.
(May be worth checking with one of the reviewers to check actual dimensions.)
Canuck
I pulled this from one of the reviewers comments......
"What's the Search term:actually Search term:dimensions? Looking for roughly 11 5/8 × 23 1/2
A: Interesting question. I went and measure mine. The 12x24 Search term:dimensions are for the exterior filter, and the internal unit is ~11.25 x 23.25".""
ScottM
Following as I have the same unit and I am in need of a new filter too.
V
vbgregg
Gregg
I found many vendors on Amazon, but they often only give the nominal 12x24 measurement and not the actual size, which needs to be more like 11 3/8" x 23 3/8" x 5/8". And I have never heard of those vendors and they have very few ratings, so I'm not sure I trust the quality of their products. Someone mentioned Wynn Environmental, and I have heard of them, so I called and they have a 2-pack for $92 plus shipping and probably tax. They specifically list the JDS 750-ER on their web site. Here is the link:
For me in Raleigh, the shipping is $14.56 (but supposedly no tax), so the total is $106.56 for 2 filters. I may try this. They are more expensive than many of the Amazon sellers, but probably more reliable.
Someone suggested calling local HVAC companies. I called 5 or 6 this morning, but none of them sell individual filters. If anyone knows of a local HVAC company that sells these, please let us know. Thanks, Gregg
V
vbgregg
Gregg
Here is a follow-up to my earlier posts. I called several local HVAC companies, as suggested by someone, but this did not work out. Nobody had anything the right size. Actually, I could order one from Grainger (who has a local shop in Raleigh), but the guy actually recommended that I get the ones from Wynn Environmental.
I ordered a pair from Amazon, and they sort of worked, but I think I will return them. The metal frame was the right size, but they had a gasket around the edges that made it impossible to fit in the JDS 750-ER slot. I removed the gasket and it fit fine. I then re-installed the gasket on 3 of the 4 sides (top and both ends) and I was able to squeeze it into the slot (barely). The original pocket filter did not have a gasket, so I was not sure whether that helps or hurts. Maybe a tight fit is a good thing. My main concern was that the vendor was not anyone I had heard of and soon after I ordered, Amazon listed them as unavailable. The price was great ($48 for the pair), but I worried about how to know about the quality and whether the advertised specs were reliable.
I ended up ordering a pair from Wynn Environmental, who I have heard of and have been around for a long time. They fit fine and did not have a gasket, which I still wonder if that's a good thing or a bad thing. They were more expensive ($92) and the shipping was more than originally stated ($18), so the total was $110, but I trust these more than the ones from Amazon (though who really knows). I will probably keep these and send back the ones from Amazon.
