Long bed lathe for sale
bob vaughan
Bob Vaughan
Here's a nice long bed lathe for sale. Baldor DC motor and Baldor DC controls. The lathe is comprised two Delta 1460 lathe beds and cast iron legs joined together. The outboard disk is a round table top that was work in progress but was never finished. I've seen this lathe and was impressed with it. It could be cut down to be one 12x36 lathe. In Roanoke VA.
https://roanoke.craigslist.org/tls/d/roanoke-delta-10-lathe/7236417241.html
It'd be great for making porch posts for an Antebellum home....... Curious to see how the face plate is threaded onto the outboard end of the headstock and secured without trying to spin off when turning, unless he has a reversible motor setup and turns from the backside.
bob vaughan
Bob Vaughan
It was built in place. I suspect that the best strategy would be to take it apart and move it.
The original intent was to turn tall bed posts for a canopy bed.
The faceplate just screws on to the 1"-8 Left hand thread that's standard on the 1460 lathe. It probably should have been removed for the photo.
The motor is electronically variable speed and reversible but reverse would spin the faceplate off.
chris_goris
I once knew a woodworker who used to do just that with a square to round adapter wedged in place and a steadyrest on a 60" lathe. He grabbed the stock with a 4 jaw chuck. Turned half and reversed it. Worked well and quite ingenious really.
bob vaughan
Bob Vaughan
Sometimes a man's gotta do what a man's gotta do.
bob vaughan
Bob Vaughan
Actually I've seen a rig similar about 30 years back in Salem, Va. There was a high end furniture maker that had a huge ball bearing bearing fitted with a square center. The steady rest would tighten on the bearing's outer race.
Board of Directors, President
He has a VFD (above the headstock) likely forward and reverse and what looks like a Baldor DC motor - mighty fine set-up for an antique lathe!
Better not lose that 1"-8 LH thread face plate. No reverse needed if that's the case. I'd think that face plate would be as scarce as hen's teeth.
bob vaughan
Bob Vaughan
There's also a pile of very expensive chisels that go with the lathe.
I'll probably see that lathe within the next week.
If my son and I didn't have two lathes each, I'd own that.
The owner was a long time woodworking buddy. I think his inspiration for that rig came from seeing my 1460 that I put a DC motor and controller on back in the late 1990s. That was in the days when a VFD was almost unheard of in the woodturning world.
6" cast iron left hand Delta faceplates are not all that uncommon. Delta even had an aluminum 3" faceplate that had cross threads to one could either go outboard or inboard.
