I have no doubt LN planes are really good, but I have a little problem with their pricing. For example, a no. 1 is $285. A no. 8 is $550. They both have the same number of components, obviously the bigger plane has slightly bigger components but the biggest difference is the amount of steel. Volume/setup time is probably the next biggest factor. I would guess #4-8 use the same handle & knob and #6-8 use the same iron/frog etc.
*** Skip to the bottom if you don’t want to nerd out on numbers ***
The #1 is 1.35 lbs. while the #8 is 10 lbs. So that’s $265 for 8.65 lbs of steel, or $30.63 per pound. Tool steel is between $4-6 per pound. Humm.
So now compare the #1 at 1.35 lbs $285 to the #2 at 3.25 lbs. $315 a 1.9 lb.-$30 difference, or $15.79 per pound. Comparing the #2 to the #3 at 3.5 lbs. $345 it’s a $30 different again for only 0.25 pounds, or $120 per pound!
#4 - $375 + $30
#5 - $385 + $10 (probably sell more of these than any other size)
#6 - $475 + $90
#7 - $500 + $25
Good used Stanley planes can easily be found between $40-150. You can get a motorized bench top jointer for about the same as a #5. The least expensive 6” stand alone 1 hp jointer is around $1000 now days. Don’t get me wrong I love quality tools, but there a big enough gap between LN and Stanley to justify it, or is it just a case of I got the money and I can’t take it with me, so why not?
#4 - $375 + $30
#6 - $475 + $90
#7 - $500 + $25
