Laser / Engraver
ScottM
I know a few of you have gone down this path already. I have seen it in some the recent projects posted. No I am not thinking about selling my scroll saws but I am thinking about adding one to embellish what I already do. Since I am about to get a $600 windfall, thanks to the new stimulus bill, I am thinking that's about what I am looking to spend + or - a little. Any advice or recommendations? PLEASE NO COMMENTS ABOUT THE STIMULUS OR PANDEMIC.
beloitdavisja
James
It really depends on how large a work area you're wanting, and if you want the ability cut as well as engrave. If you want to do any cutting, you'll be looking at a CO2 laser, as opposed to a diode laser. These typically are rated 40+ Watts of power. With a
In the sub-$600 range, the most popular option is a K40. They have a 12x8" work area, 40W CO2 laser, and a large userbase for help. They run $4-500. There aren't really any specific brands for the K40 - it's just a blanket term used for the 40W lasers that are imported from China. They are all over eBay, and my suggestion would be to find a US-based seller with good reviews. There are also tons of videos on YouTube on how to use it.
Remember you also have to have software to run it. There's a free option for K40's called K40 Whisperer. There's also Lightburn ($80, free trial), but I think for the K40 you need to upgrade the stock controller, which just doing a quick search looks to be about a $2-250 upgrade. For designing the graphics, I use Inkscape, which is a free vector graphics editing program. You can also use Adobe Illustrator if you want to pay for it, or already have a license. I know there are some others out there as well.
Going bigger than the K40, things get expensive quickly. My laser is the "50W Blue & White," and that looks to be going on eBay for about $1600 these days. It has a 50W laser, and a 12x20" work area. I use RDWorks for the software (free, but RDWorks is only compatible with Ruida controllers, which my laser has). I'm considering getting Lightburn for it at some point, but RDWorks does fine.
Stepping down from the K40 is mostly diode lasers. They come with terrible software, but some you can get to work with Lightburn if you change the firmware. I started with a 2.5W diode, and the software was sketchy and quite a pain to deal with. I only used it to engrave. It could probably cut some card stock paper, but nothing more. I recently gave that one away for free to another NCWW member that wanted to play around with a laser. I changed the firmware to run LaserGrbl, another free program that was compatible with the controller. My recommendation: Buy a CO2 laser if you can afford it.
Lastly, some safety notes. 1 - Don't ever run it unattended. These things have a serious risk of fire. Before I got my laser, I had a guy in Charlotte do all my engraving. He had a major house fire caused by his laser because he left it unattended for a short bit. 2 - if you're doing anything other that wood, check to see if it's safe to laser. PVC, for example, is an absolute no-go. It creates chlorine gas which is not only highly toxic, but also corrodes and destroys the laser equipment.
kserdar
For ease of use, I can recommend the Glowforge. You will need to spend more then the $600.
My biggest complaint about it - The exhaust fans are extremely noisy. There are external third party fans that work better and are quieter.
