Laguna 150" Resaw King Bandsaw Blade - Sale Pending
bobby g
Bob
Very lightly used 150" Laguna Resaw King Blade.
Here is what Laguna says about it:
LAGUNA RESAWKING 1 " X 2-3 VARIABLE TPI X 150" BANDSAW BLADE
The Resaw King is the ideal blade for anyone cutting hardwoods or exotics, providing ultra smooth cut quality with minimal material loss. Nearly a decade in the making, the Resaw King has been skillfully finessed into one of the best woodworking blades in the world. Created by Torben Helshoj, an award winning woodworker, the Resaw King displays his passion for the art.
Made from a C4 carbide tipped alloy, the Resaw King can be resharpened 4-5 times! Variable tooth spacing significantly reduces vibration while producing sleek smooth cuts. This dynamic blade also cuts down wood waste due to its ultra-thin kerf and backing material, saving you money. The Resaw King is manufactured in Germany exclusively for CET and is perfected here, in the USA, by our skilled team of professionals using our full line of CNC machines. Little if any sanding needed after each cut, produces an extremely smooth cut you will have to see to believe. Specs: C4 Carbide Tipped. RESHARPENABLE. Backing: .024″ – .6mm. Pitch: 12mm, 14mm, 16mm. T.P.I. 2-3 Variable. Kerf: .044″ – 1.1mm
I'm selling it because I no longer have the saw that it goes with. $75. Located in Pittsboro.
