Bowling Alley Wax has been around for a long time. It might be a viable replacement for Johnson's Past Wax.My shop is finally built and starting to get everything set up. I came from a dry desert climate and always used Johnson paste wax to keep slick and rust free. Since no longer available, what are people using as an alternative? Thinking about trying Briwax original (no color).
I did up a batch similar to this some years ago using a crude double boiler configuration to make sealing paste for log ends. It would probably work just as well for polishing the shop tool surfaces.Never used Johnson's Paste wax. Always used a shop made remedy, parraffin shaved thin, dissolved in odorless mineral spirits. Using a box grater, shave some parraffin into a container containing odorless mineral spirits. Cover and let it sit over night, then put into a spray bottle. Clean surfaces of existing rust and dirt, spray with solution. Using either a rag or paper towel, wipe surface to spread solution. Let MS evaporate, then buff surface with a clean rag or towel. SLICK!
