I knew I should have collected JPW instead gold! LOLWalmart is reselling JPW for only $207.97 for a 16 oz. can. Hurry while supplies last!
I remember the Zayer that used to be on Patterson Ave. in Winston-Salem. That makes that can at least 36 years old.Zayre’s Dept. Store
I bought that can in the early ‘70s in BurlingtonI remember the Zayer that used to be on Patterson Ave. in Winston-Salem. That makes that can at least 36 years old.
Look at Mold wax. It is available on Amazon. You want a non-silicone waxI am just looking for a product to protect my cast iron tool tops. Any ideas?
I've heard the Carbon Method works great but is a bit pricey. I still use my JPW, although sparingly now to make it last. Figured once I run out, will look into the Carbon Method stuff. I also use Boeshield T9 as a lubricant every once and awhile to keep the tops as slick as possible.I am just looking for a product to protect my cast iron tool tops. Any ideas?
I've tried it but not on any tools. I used it on an outdoor bench I built a few months ago to give it better protection against the elements. So far, as a coating it works extremely well, however, when you apply it, you need A LOT of ventilation and a respirator because if not, and you breathe it in, it can harden in your lungs and cause serious issues.Has anyone tried the liquid ceramic coat products out there for car finishes?
My son has used Chemical Guys “Hydro Charge + Ceramic Spray Coating” on his truck. He expects it to last a year and it’s very slick, extremely easy to apply, and won’t shed onto wood. May be worth a try.Has anyone tried the liquid ceramic coat products out there for car finishes?
