I am preparing to retire and decided to buy a SawStop PCS, 1.75hp over a month ago. I wanted it to be at the 38+ inch height of the Ryobi BT3100 on it's custom base so that I could continue to use the same outfeed/work table and so that wood could extend over adjacent machines. Plus I do not like a 34 inch tall saw. So I could use the SawStop bases. I initially planned to put workbench wheels on a 2x4 and plywood base but the ones I was looking at would not support the SawStops weight. So I switched to a PortaMate 3500 rated to support 650 lbs. It works but I would not want anything lighter. I built a base, put the saw on it, did not like the way the extension table was supported nor did I like the amount of weight on the left side front wheel of the portable base. So I extended it in both directions. The two legs that came with the SawStop for the extension table are removed and the table rests on a storage chest that rests on the same mobile base. I am still adjusting to the new tool but i generally like it. It is certainly the nicest table saw I have owned. Here are some pictures.
