After some trial and error, I have progressed to breaking into my 12/4 cherry and tweaked the set up. I was having a lot of problems with burning at the exit and entry points that was causing me a lot of frustration. With the help of a friend on another forum, I decided to switch to a speed control router and as suggested, approach the entry/exit points from the middle and immediately pull the bit away. I am quite pleased with the result and I think I'm ready to use my premiere wood.
For some backround on the project, see the previous posts:
www.ncwoodworker.net
BEFORE
AFTER:
What are you making?
I am near the end of my gate project and thinking about the next several designs I want to build. So, I was wondering what everybody else is working on. Even if you are not ready to show it to the world can you please just give us a hint? One of the things I have worked on and built several...
Jewelry Armoire Project -- turning a dowel a new way
Although I was able to produce a sort of decent rod with standard lathe tools, my skill level is too low and I don’t have the time or inclination to practice. So I came up with this idea using a router. The surface is a little rough but this is cypress. It sanded out nice and smooth. The...
BEFORE
AFTER:
