For Sale JessEm Mitre Excel I Miter Guage
Ed Fasano
Ed
$200.00
This is the original version of the Mitre Excel Miter Gauge. It is all but new and includes the original packaging. This gauge has undergone a one-off hand calibration and adjustment by the folks at JessEm in Canada, further ensuring its accuracy. The image of the shipping label validates JessEm's shipment to me after the calibration. Includes the original packaging.
The head and fence are made from heavy-gauge aluminum. Large and small brass locator pins adjust the miter-head setting accurately up to every half degree. You also have the option of setting the angle manually. The steel miter bar has two adjustment mechanisms to provide a slop-free fit in the miter slot. The fence and very solid flip-stop provide 36 in. of total crosscut capacity, including the sliding fence extension.
My table saw use isn't what it once was, and a variety of sleds seem to address my crosscut needs. This is a beast of a miter gauge, priced well below JessEm's current offering.
Highlights From JessEm's spec sheet:
  • Heavy duty design and construction provides exceptional dampening with increased rigidity resulting in greater accuracy through the cut.
  • Precision CNC machined from solid 6061 aluminum, solid steel and solid brass components.
  • JessEm’s Innovative Dual-Indexing Angle Location System provides precise “positive stop” angle locating to every ½ degree and a separate vernier scale allowing additional angle settings to 1/10th of a degree.
  • Heavy-Duty 24” extruded aluminum fence extends to 36” over all with an innovative Dual-Reference Adjustable Scale for accurate cutting measurements.
  • 20” solid steel bar with “T”-Slot washer fits standard ¾” miter slot.
  • Adjustable snugger bar design to eliminate slop in the miter slot.
  • Adjustable flip-stop for repeatable measured crosscuts.
woodlaker2
Ray
Didn"t see it in your pictures. Does your unit have the "micro adjust" feature (rides on top of the fence) or did Jessem add that later?
Ed Fasano
Ed Fasano
Ed
No, it does not have a micro-adjust. I believe that they added that when the $380 version was launched.
