I have a Laguna 16HD bandsaw--a big honking 3hp, 220v bandsaw that will power through any resew. I've done 10" wide white oak with no problems. I have changed between 1" blades for resawing to 1/4" blades for scroll work 10+ times with no problems. I was getting easy, straight resaws with no wavers with the 1" blades.
I was resawing cherry, and the cut started bogging down and then wandered off flat causing a badly uneven resaw. All of a sudden the 1" wide blade snapped; I've been told these wide, thick blades never should break. When the blade broke the tensioner slammed down to zero tension. It was almost impossible to get the broken blade off because the flywheel tensioner is now stuck. I can't get the adjustor to turn in either direction. I don't want to remove the blade flywheel until I know exactly what to do to repair the saw. The manual doesn't have any helpful information.
Has someone been through this breakdown, and can you tell me how to fix it? Short of that is there anyone in the Asheville area who does mobile repair on machinery? My shop is shut down until I can get the bandsaw operating again. Thanks.
