I need an idea..
Chris C
I have to make two presentation cases that will hold a brick. A square box won't do. I just can't think of anything that stands out. Open to anything.
Ideas?
Martin Roper
Martin
Ideas?
Clock glass dome on a turned base? The brick would be displayed on end.
So, we’re looking for a theme here.
What or who will the brick be for?
maybe you want to pm that. Or mask the answer in some way. I’m just looking for clues to a theme that will lead to a design.
I usually think in pictures but words help bring the pictures sometimes.
Like a brick in a wall.
thoughts begat designs just as designs should bring words to mind.
not just random box for a random brick. The brick has meaning as the container should have meaning.
Chris C
They were bricks from the cornerstone of the original courthouse here. One of the resident superior court judges is a good friend of mine and asked me to make something to display them. I suggested a box style presentation and he said no..... And offered no other ideas.
DSWalker
Does he have access to any wood from the courthouse? Brick inset in a piece of wood, could be a base for a Gavel, also potentially made from remnants from the. Courthouse.
Or brick could be a base for scales.
Graywolf
Board of Directors, President
Richard
I like the idea of insetting a brick into the wood, if it were a piece of timber from the structure even better. Add a small plaque expressing the origins and dates.
NOTW
Notw
I think I'm with Linc on this one keeping it simple, most of the time when I have seen bricks used as awards they had a plate on them denoting why they were special and nothing else, mounting it to a single board makes it even better
Grimmy2016
I like the brick as the Foundation of the Justic System. Is this the type of brick with 3 holes in the middle? Maybe run some dowels through those, mount a board on the ends above the brick and build a small courthouse box to hold (cigars, pens, etc) I also like the idea of the scales.
Linc H
Linc
Make a desk top stand that the brick can sit on. with inscription denoting key event.View attachment 206209
And you may want to even consider routing out a space 1/2" or so for Brick to sit down in the base and could epoxy so it so it is more permanent if need be. Certainly lots of more creative ways to improve the base, however you get the idea. Simple and functional.
What about a small section of "wall" made out of wood bricks, with a contrasting color for the mortar. Leave a space in the wall where the real brick goes, protruding about an inch or so.
charlessenf
Charles
... something to display them ...
Them?? Several bricks in a display? Or Several displays with one brick each?
Here you go..... It was renovated in the 90's but this is how it originally looked.
That roof detail might do for a horizontal presentation case with glass on front and sides - plaque above the brick or on the base. We really need to know where your pal thinks they will be displayed - on a flat surface? On a wall? In a display case? I suspect they might have a place in mind if they are looking to memorialize the old building.
One way to focus the mind is to ask "What is the budget?"
