I need a new saw for cutting my bowl blanks
Due to my hand injury I can't crank my Stihl chainsaw.
What is a good or best battery powered chainsaw?
I could get by with 110V on a cord but sometimes I need to clean up windblown limbs in the yard.
Are any of the battery chainsaws good enough to cut 12-16 inch thick wood once in a while?
I'm not cutting big piles of firewood anymore.
J_Graham
Graham
I have a 14" ryobi 40v that I like. Weight is good, the stock chain that comes with it is pretty terrible, but after you replace that its pretty good. Never going to be like a gas powered, but a good replacement for smaller work.
rcarmac
Board of Directors, Secretary
Robert
I have a 40v Kobalt chainsaw. Its really made for limbs and branches. I have used it to cut through 12-16 inch stuff. Its just slow and you are only going to do that a couple of times before draining the battery. This was my first battery powered. I have been looking a little at the Stihl Battery Powered and will likely go that direct once my Kobalt dies.
tvrgeek
I have the 80V Kobalt as I also have the 80V blower. Quite happy with it but I wish chain tension was tool-less.
I have had it several years and I suspect others have improved. E-go, Green Machines. and I forget which is partnered with Sthil. For occasional use, I guess even a Roybi would work. I would go for the bigger with higher voltage batteries. Might consider what else around the yard you could go cordless and pick the line that best serves you. I also run the Kobalt 40 V in string trimmer, pole saw, and hedge trimmer.
It does not cut as fast as my little Pulan, but it starts with the trigger every time.
I think I saw a Y-tube review but I did not watch. So many are bogus and rating based on what the box says or what they are paid to say.
Mrfixit71
Board of Directors, Treasurer
Rich
I have an EGO 17" for the same purposes Mike is looking for - cutting blanks, limbs, clean up, without having to crank up my Stihl Farm Boss. The EGO will cut 12-16" hardwood with no problem and has a pretty good battery life, depending on what you're cutting. I'm very happy with it.
KenOfCary
The Stihl electrics look good and it is a quality brand. Can't say for sure as I haven't used one yet. They also seem to have a good dealer network that supports them. They're sold in most of the farm supply stores around here.
tvrgeek
Ego I think. Stihl bought into them as a joint venture. Probably slightly different than their own branded tools. I could have them confused with Green Machines. Anyway, the two big hitters.
JaredG
Jared
I have the Greenworks 40 V 16 inch Model #20312. I like it but have no point of comparison. I already owned their lawnmower and weedwhacker so I stuck with the platform.
ashley_phil
Phil Ashley
i bought an older version of this greenworks saw in 2018 and it has served me well. given the infrequency i use it i couldn't justify the extra cost to go battery.
Greenworks 10.5 Amp 14-Inch Corded Chainsaw 20222​
ssmith
Can’t comment on Greenworks chainsaws but +1 on their tools.
We have their 60V push mower and it’s well-built and has worked flawlessly.
Roy G
Roy
Mike, I have a Makita 16" cordless chainsaw. It uses 2 18v batteries. I have recently been using it to cut up some parts of a large oak I had taken down. i can cut up 36" diameter logs by going from both sides. The batteries last long enough for me to do several cuts on the big stuff and a lot of smaller cuts on branches. I went with Makita because I think their quality is higher than Ryobi and I didn't know how well the other brands were built. Also I didn't want a 56v or 80v chainsaw because those boogers are heavy.
Roy G
Bryan S
Bryan
While I have not yet made a purchase, The reviews I have read gave Stihl the highest praises and said it felt the most like the gas powered. Of course, Stihl is the most pricey if I remember right.
Craptastic
Stay away from Worx. Bad chain alignment management. I like the Makita I've borrowed from the neighbor a couple of times. Saves me from firing up the Poulan gas fired one for just a few deadfalls.
If you need any worx batteries I have a couple of them and a charger sitting here you could have for just coming over an picking them up.
If you need any worx batteries I have a couple of them and a charger sitting here you could have for just coming over a picking them up.
But… you just said stay away from WORX.
I have been very loyal to Stihl. $700 is a bit steep so I’m wondering if a smallish one would be usable. They have one for about $400.
One of my local friends has a green works pole saw and swears by it, not at it. But, I saw some bad reviews.
I think Greenworks and EGO are two brands to look at - I swear by (not at) our EGO blower... but a blower is MUCH different from a chainsaw...
golfdad
Co-director of Outreach
Dirk
Mike I have a elec Worx and it works fabulous.....I would buy another one in a heartbeat
