A few months ago I bought a Central Machinery 8" bench grinder from Harbor Freight for about $50. Not the one with the light. OK, it's definitely a piece of typical harbor fright junk but it seemed heavy duty enough for grinding and sharpening lathe chisels. The truth is that if I had seen one without the grinding wheels mounted or running and leaping all over the bench with its wheels wobbling merrily side to side I'd have run away.
Being stubborn I decided to see if I could do anything to make it actually usable since I had bought it.
The short version is that I cleaned up the arbors, bought a Norton blue wheel, replaced the stamped wheel flanges with machined table saw blade stabilizers (really!), dressed and trued the wheels, verified wheel balance and now it's actually a usable grinder.
Not counting the cost of the new wheel, which I'd have probably bought no matter what was on the grinder, it cost me about $22 and a couple of hours work to make this thing usable. The details of what it took to do this are, as usual, on my blog. Way too involved and long to post here.
http://jrwagner.org/blog/2013/08/05/bench-grinder-hacks/
As long as the motor doesn't go up in smoke I should get quite a bit of use out of this grinder now.
