How do you glue up your doors?
Willemjm
Willem
This is how I do mine, use Titebond III so I have more setup room and a clamping system that keeps them perfectly flat. Then a few pin nails and out of the clamps.
Taking a break to post here, the shop is overloaded with work, seems the big shops are all closed? This was supposed to be a hobby, but can’t get time to build nice things any longer. What sells are the cheap painted stuff with lots of plywood. Lot’s of money there with orders from companies doing mostly pre-fab and then they end up with custom requests.
Looks nice and much better suited to higher volume than my hobby shop methods. I just clamp them up for an hour and then do the next door. I do like to clamp on my outfeed/assembly table which is flat so the door has a better chance at being flat. I don't have a problem with flat panel doors using plywood panels, however.
Skymaster
Jack
Willem, great setup, however it takes a bunch of time. I have found that I glue and clamp face down when square I use 5/8 brads right thru into the tongue , pull em out of clamps repeat. no need to remain in clamps. so far everything stays flat and square. Trying to help ya my friend also tbond 2 better much faster set, max of 10 mins and you cant break the bond without a hammer
Rwe2156
DrBob
That is a nice system but personally I don't find cauls usually necessary. I set the door on 2x2's and use parallel clamps. The 2x2's keep the doors off the clamp bars and enable me to tweak the clamps to correct squareness and flatness.
I use TBII and keep them clamped 1-2 hours.
Willemjm
Willemjm
Willem
This is what I am building BTW, a day and a couple of hours into it so far. Install and granite top by others. Now comes the challenge, dark grey blue spray job and moving it around alone.
Thanks for all the advice posted, appreciated.
pop-pop
Man with many vises & whackers
Sometimes this happens during clamp up and I miss it until it is too late:
Because of that I always use cauls to remove that possibility.
