I have a cabinet that is using 1/2 plywood for the cabinet and the doors are 3/8 plywood. The doors are not inset. The cabinet portion is 3 inches deep. will be used for key storage and a lot of keys. The dimensions of the doors are 24" H x 10" W . Two doors. Suggestion on the type od hinges that can be used. I do not mind if they are seen as the key storage is not out in the open. However, they can't be overbearing either. I tried various sizes of these from home depot but are way too gaudy looking or were not big enough to secure on both pieces. Suggestion?
Kurt
Everbilt 3-1/2 in. x 1/4 in. Radius Satin Nickel Door Hinge 14985 - The Home Depot
Make use of this Satin Nickel Door Hinge for upgrading the hardware in your home or while installing new custom doors. Made of steel.
www.homedepot.com
Kurt
