HF 18v cordless impact driver
DavidF
Just a note to say I bought one of these at the weekend for work, for putting together crates at exhibitions etc - On sale $27! boy whata tool! may not look too pretty, but it packs a punch! variable speed 0-2400 and the neatest battery charger I have seen in a long time - so far, and only time will tell, I would recomend this tool. Plus, an extended 2 year warranty was $5.99!!!!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94855
fsdogwood
Pinwu
Thanks for the info. I also found another one from HF:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90798
named "[FONT=arial, sans-serif]18 VOLT, 3/8'' CORDLESS IMPACT WRENCH" with the following:
[/FONT][FONT=arial, sans-serif]Powerful 1044 inch lbs. of force to help you power-off or power-on bolts and fasteners. [/FONT]
  • [FONT=arial, sans-serif]
  • 1700 blows per minute
  • Variable speed 200-1400 RPM for controlled starts
  • Rugged metal nose piece
  • Cushioned palm grip
  • Lightweight--only 5.5 lbs![/FONT]
DavidF
DavidF
Can it be used for screws, David? I notice it has a square drive.
Thanks
Yes, I have a 1/2" drive adaptor to convert to phillips screw drive and as it is continuously variable speed it makes control easy. It has no clutch on it so probably wouldn't use it to repalce a "normal" drill/screwdriver, but for those heavier jobs it's the dogs'. (that's a good thing!)
