Well, to all reply's ... thank you. And no I am not an idiot
, but I am somewhat new to this type of finishing. I've built cabinets in a previous home and spray finished these with paint. So yes ... I know how to spray - I've just never done lacquer and don't know the idiosyncrasies with the process. I assume this is like a lot of things wherein - it's easy once you know what you're doing.
I think the culprit was I probably wiped the wood down with mineral spirits. It was either that or paint thinner - I don't remember. Also, the brand of the spray lacquer is a Rust-O-Leum, clear high lustre.
I do have a few questions:
- do a lot of the sanding pads have silicone such that it contaminates the wood? I bought 50ct packs off e-Bay and likely came from china.
- does wiping down the wood with lacquer thinner remove the silicone
- is there a particular brand of lacquer thinner with the best results
- would lacquer thinner possibly soften the epoxy pour on the wood
- does the finish coat get lightly sanded/scuffed between coats
- is there a brand of spray can lacquer that gets good results - if not what I'm using now
Thanks again ... Ciao - Dorm
