Wanted Help turning antique piano into bookself
Tag when looking for an item
Cj123
CJ
I'm looking for someone who can turn an antique baby grand piano into a bookshelf for my daughter. It was her first piano, no longer usable due to cracked sound board, so I'd like to have this done as a graduation gift.
I'm in the Raleigh-Chapel Hill area (RTP)
Thank you,
Courtney
That is a large project and the oddball kind of thing I like to do but, it will take a large space to work in which I don't have. And there is the size of the piano to consider. I assume your daughter has space to display such a work of art. I also don't have a way to transport it. So my thoughts are theoretical. I would take out the works, and any extra parts not needed for the bookshelf. All that has to be ethically disposed of... I would save the legs and use them to lift the shelf off the floor at least a foot to 18 inches or so. If the top could be used for shelves that would save the cost of new lumber. The edges would have to be finished to match the top. There would have to be a back for structural integrity, It would need a 'piano quality' finish to match.
This is a lot of work to do well. If I had the space to do it I would have to charge 2-3K.
mattfrit
Dont forget that the iron harp (the plate that all the strings are attached to) may weigh several hundred pounds. That's probably half the total weight. If that can be removed before transporting it, you might get more bites.
Def need pics.
SJWiehe
I've done two of these. The woodworking isn't terribly complicated; it's pretty straightforward. The challenge is the cabinet, the finish and the weight. The body of the piano is a glue lamination with a veneer cover. In fact, all of the parts of the piano are veneered plywood. Very little solid stock.
What you see for the bookshelf is a lot of the piano that wasn't designed to be viewed, i.e. under the harp. As a result you will end up veneering a lot of the interior of the piano case. With the amount of the new veneer, the whole bookshelf will need to be refinished to get the new veneer to match the existing veneer.
Attached are two pictures of one of the projects. It was a mahogany veneer with a brown/red stain. The shelves are made from new material and are lighted. He wanted the shelves lighted as he uses the piano/bookshelf to display his Grammy awards.
Yes, the harp is heavy. I used a chain hoist and gantry to get it out of the piano body. It's cast iron so you aren't picking it up by hand. If someone wants to tackle the project I'm happy to share my experience.
JD52M
Beautiful work! Certainly an heirloom.
What do you say to Mike’s estimate of $2-3k for the cost?
I'm interested in doing this myself one day with a BG that won't keep tune. It's being stored in the garage on its side with the legs knocked off. For those who don't know, the legs are held on by a steel dovetail plate mortised into the two members and anchored by a large wood screw. Remove the screw, and slide the leg assembly back and it pops out. It makes moving one a simple almost one man operation with the body on its bass side on a dolly.
Progress pics would be very interesting. The word of caution to anyone attempting this I have been told is to buy a tuning wrench and take the tension off the strings incrementally. Each note has 3 strings and it is recommended that the tension be removed from one string of each note before going back and doing the second and third strings. HTH
mattfrit
That's really nice. Do the foot pedals have any function, like turning on and off the lights?
Jeff Schmucker
Pay attention to Dennis’ caution about the tension in the strings. I looked into doing this with a piano at our church. I was told by multiple people that if you don’t gradually de-tension each string with the proper tool, a catastrophic and high energy failure of the casting is possible. The last thing you want to do is reach in there with a pair of side cutter pliers and start snipping wires at random.
SJWiehe
For the piano's I just pulled the harp from the body and left the strings attached. The harp thru bolts to the piano body and I didn't need to bother with the strings. I might have had a couple of strings to remove but it wasn't much as I don't remember that part of the project taking any time. The scrap metal dealer was ok with the harp and strings attached.
The keys made some interesting pieces. I'll have to find a photo or two of what I did with the keyboard.
JNCarr
Beautiful work, Steve.
My first thought was to convert the case into a liquor cabinet, or a 'piano bar'.:rolleyes: But since I don't drink that much I figure the bookcase idea might be a better choice.
ashley_phil
Phil Ashley
ii talked to a lady about doing one of these last year. i opted not as i really don't have the room
JSFoster75
I haven't done a baby grand, but I have done an upright piano... I just cut the wires with a pair of snips, no danger of "catastrophic failure" on that style of piano... While the wires are under tension, it's not a great deal of it, and cutting them one by one shouldn't be an issue... Cutting them all with a grinder in short order might be a very slight cause for concern, but cast iron is quite strong and I doubt it would break apart...
If you can find a tool that fits the head of the pieces the wires attach to, you can use a drill to back them out. I tried a few things but never found something that fit, but that's been many years ago, I'm sure there must be something out there that would work.
I went online and found a tuning kit for ~$12 that had the wrench and something else in a little felt drawstring bag. Not done it yet but I taped it to the piano for when I do and I don't have to look for it.
ErnieM
Ernie
Please, please don't take this very bad advise. I've been a PTG registered piano technician for forty years and spent much of that time restoring pianos. All pianos, grand or upright, have strings that are under tremendous tension - up to 60,000 lbs of tension. Cutting them off one at a time with a pair of snips is like playing Russian roulette with a gun. You may get away with it, but you may not. Why would you take such an unnecessary risk? Take Dennis's advice in an earlier response and remove the tension gradually. It will only cost a few dollars to buy a tuning hammer (you don't need a professional model). Isn't that worth your eyesight or an even worse tragedy? Cast iron has a very high compressive strength but is quite brittle. It can implode quite easily and you don't want to be near it when it does.
I'm too old to heal up real fast so I have to be more careful than some of you young whippersnappers. But you don't get to be old by being stupid and the cemeteries are full of dead 'heroes'.
