Harpsichord Project Part 15B - Pinblock & "Nuts" con't.
ErnieM
Ernie
Hi all,
This post is the continuation of Part 15A.
The next step is critically important to the proper functioning of the instrument. We must accurately mark the positions of the two nuts on the pinblock as well as the position of the 102 tuning pin holes. To do this, we cut out the pinblock portion of the printed blueprint and tape it to the top of the pinblock.
First we’ll position the two nuts. Small holes are drilled thru the nuts – one at each end and one in the middle of each nut. Small rectangular pieces of scrap soundboard spruce, with a hole drilled into their centers, are used as clamping pads. The nuts are placed in their proper positions on the plan and a thin wire nail with a large head is driven through the holes we drilled into the nuts and into the pinblock. These holes in the pinblock will serve as positioning holes when the time comes to glue the nuts down. The next photo shows the nuts nailed to the pinblock.
Next, using a small hammer and an awl, we’ll mark the positions of the 102 tuning pin holes by tapping through the center of each hole on the blueprint, leaving a small hole on the surface of the pinblock for each of the 102 holes.
After these holes have been marked, the nails are pulled out of the nuts and the nuts are removed. Then the blueprint is removed from the pinblock which now has 108 dimples on its surface – 102 for the tuning pins and 6 which are the nut positioning holes. Here’s what it looks like.
Now we’ll go to the drill press and drill the 102 tuning pin holes. The tuning pins must angle backwards about 5 degrees from vertical. This helps them resist the pull of the string tension. My radial drill press tilts in every direction except the one I need, so I use a simple, shop made drill press table which is angled at 5 degrees.
The holes are drilled with as much uniformity as possible. Each hole is drilled half way – the bit is lifted to clear the chips – the hole is completed. We’re trying to get the holes as uniform in size as possible because this will affect how easy or difficult it is to tune the instrument. We’re not terribly concerned about the pins being too loose because, unlike a piano which may have 160 lbs. of tension pulling on each tuning pin, the string tension on a harpsichord is much, much less. As long as you can’t turn the tuning pin with your fingers, it’s tight enough. Too tight, on the other hand, is really bad on a harpsichord. The amount a harpsichord tuning pin is turned during tuning is so small that a too-tight pin makes fine tuning difficult, if not impossible. By the way, we’re drilling the holes with a 3/16” bit (.1875) to accept a tuning pin that has a diameter of .198. Here’s the pinblock being drilled at the drill press.
And here’s the pinblock after all the holes have been drilled.
Now it’s time to do something very simple ..... if you do it at the right time. We need to cut a small 3/16” dado into the bottom surface of the 8’ nut. A brass control lever must go underneath this nut and the dado allows for this. I once glued this nut down without cutting this dado. Can you imagine how hard it is to cut a dado on the bottom of a piece of wood that has already been glued down? It took forever. Being as smart as I am, the next year, on the very next instrument, I did the same exact thing – what an idiot! Anyway, this time I remembered to do it before it got glued down. Here it is.
Next, we’ll glue the nuts to the pinblock, using the positioning holes to align them in their proper places.
After the glue sets, the positioning nails are removed and the holes plugged with glue and a toothpick. And here’s the result of our work – the pinblock installed in the case (but not glued and screwed down yet). I’ve cut and fit some spruce to cover the screws at the end of the pinblock.
And that’s it for this session. We’re now exactly 9 weeks into this project and some decisions have to be made about what level of detail to include in future posts. This is especially true in the case of finishing and decorating. I’m sure no one wants to see 15 photos of paint drying. On the other hand, paint and decoration is a big part of a harpsichord. I’ll rely on all of you for guidance. Let me know what you want to see (or what will bore you to death) and I’ll try to tailor my posts accordingly.
Till next time,
Ernie
Part 1 - The Keyboard Part 2 -Keyboard con't. Part 3 - Keyboard con't. Part 4 - The Case (Bentside) Part 5 - Case Bottom Part 6 - Case Sides Part 7 - The Lower Braces Part 8 - Case Finished Part 9 - Building the Registers Part 10 - The Stand Part 11 - Jackrail & Moldings
Part 12 - The Music Desk
Part 13 - Building the Bench Part 14 - Building the Soundboard Part 15A - Pinblock & "Nuts" Part 15B - Pinblock & "Nuts" con't.
Alan in Little Washington
Alan Schaffter
Ernie, it is really coming along and looking good!!! Don't worry about us. I doubt anyone will want to, but we can scroll over anything that might not interest us. You are the one who is spending the time to take the photographs and do the writeups, so whatever floats your boat.
I had to go to the web during my last battle with SketchUp, but finally found the answer. I was having trouble with orientation of a drawing- I didn't know about "gravity":dontknow:
I will send you an email later with more SketchUp questions though.
JohnW
Ernie.
This has been one of the most....NO, make that THE most enjoyable post series I've ever followed on the net. Watching paint dry on this series could not be boring. Judging from some of your past work, I'd very much like to see in detail how the "art" of decoration is handled.
Thanks for taking thi time to share this with us.
John W
nelsone
Ed
The level of detail is completely up to you. I am thoroughly enjoying this series and would love to see how the finishing aspect is done! I haven't painted too many of the pieces I've done, but that doesn't mean it wouldn't be beneficial knowledge!!!
Tar Heel
Stuart
Ernie, it certainly didn't take you long to recover from your sojourn up north. As has been said so many times before by so many of us, this has been a very interesting series. We have seen, and enjoyed, much of your work and now, I assume, we will see some of Sandy's. Bring it on. There's nothing wrong wih watching a little paint dry.
ErnieM
ErnieM
Ernie
Are you sure? I use oil based paint and it could take a while. :gar-La;:gar-La;
Ernie
I have thoroughly enjoyed it all. Instead of separating into different threads just respond to yourself that way it is all together.
I am interested in all of this. I suspect (or hope) the finish rivals a piano, and personally, I haven't achieved that level of finish and am interested to read about it.
Like, why use oil based paint instead of latex. All of the good stuff.
This is most enjoyable and definitely not boring. We may not respond or post, but that is because your level of detail is so thorough I at least am left speechless.
Alex Franke
Alex
I'm a late-comer here, and I'm sure you've probably heard this before, but this project is just GENIUS! Inspiring, actually . . . . like I-want-to-quit-my-job-and-try-it-myself-even-though-I-know-it's-WAY-above-my-head inspiring! I'm going to have to spend some time reading through these posts...
Do you tune it like this? ;)
(from http://en.wikipedia.org/wiki/File:Bach_loops.gif)
ErnieM
ErnieM
Ernie
Travis,
When I first started building harpsichords professionally the only negative comments I received pertained to the finish on my instruments. I heard comments like - too slick - too piano like - too shiny etc. I had spent a good many years rebuilding and refinishing grand pianos and was in love with hi-polish finishes. So naturally, when I started building harpsichords, the piano-like finishes remained. Of course, and as usual, I was wrong. Shiny finishes look out of place on a harpsichord. I was told that an entire harpsichord could be painted with one pint of paint. I was using two to three quarts. While I'm slowly getting over my hi-gloss fetish, I'm still nowhere near the one pint per instrument benchmark. For me, satin finishes are much more difficult than hi-polish. Rubbing down a finish to a nice soft and even satin is still a work in progress for me. It's still amazing to me that, after patiently sanding multi-coats of finish to get that nice smooth look I was looking for, people in the harpsichord business wanted to know why I went to such pains to eliminate brush marks. Go figure!
Ernie
Ernie, when in doubt, go for more detail. Remember, this is the kind of crowd that can happily discuss the different types of handles used on clamps for 3-4 hours. With follow-up homework :)
I can see pictures of harpsichords everywhere. But the process of making and finishing ones - good stuff! Clear finishes are favored among woodworkers, paint is considered "amateurish" by some. I think this will be good to challenge those conceptions! :icon_thum
BTW, I think the URLs to your previous posts are what's eating up your space allotment. A simple workaround is to write your article as normal, then post the URLs (which are REALLY handy to have!) as a reply.
ErnieM
ErnieM
Ernie
Bas,
I used to feel the same way until I saw this instrument at the Boston Museum of Fine Arts. It is the original 1736 Henri Hemsch harpsichord.
While the stand is all gold leaf, the rest of the instrument is painted. While it's a bit 'over the top' for most folks, it is visually stunning in person. IMHO anything that is well done is not amateurish. I hope my modest attempt at painting and decorating our instrument might change a few misconceptions about painted pieces.
Thanks for the tip about the links to earlier posts. I think I'll take your advice and post them as a reply. Going back to update each post is getting old real quick for me and, I'm sure, for DaveO who has been kind enough to constantly re-open closed threads so I could update them.
Ernie
thrt15nc
Tom
Ahhh, Ernie, the project has returned. Exciting!!! I'm another vote for giving as much detail as you want to spend time with. I'll read it all.
By the way, I got "Ima and Yura..." typed in in Google before it hit me. One of those "wait for it" deals. My wife thanks you immensely. She'll still be laughing at me next week.:embaresse:embaresse:embaresse:rotflm:
Tom
Ozzie-x
Randy
Ernie,
I have been following your tutorial and it is phenomenal. I had no idea what was involved in making a keyboard instrument (really hadn't thought about it I guess :dontknow:) You are certainly dispelling a lot of myth and magic. Keep up the good work and I'll be looking forward to the remainder of the tutorial. :icon_thum
mburke911
Hi Ernie,
I really REALLY enjoy reading your posts. Please be as detailed as you have the time. I am interested in how you do the final parts... it's all in the finish...
Thanks again,
sapwood
Roger
Ernie,
I appreciate your personal modesty, but you can be sure NCWWer is [strike]proud[/strike] honored to host your How To. Please don't stop nor omit any details :eusa_pray
Roger
ErnieM
ErnieM
Ernie
Once again, thanks to all for your support and encouragement.
Roger: I can't stop now even if I wanted to .... just bought new batteries for my camera.
Ernie
