Hanging Shelves
patlaw
My wife wants to add shelves above the doors in the small laundry room. My dilemma is how to hang them. The room is about 8 x 8, and the shelves need to run the length of two walls. I'm struggling with how to mount them. My preference is to make them using French cleats, but how do I design them so that they don't sag in the middle? If I use Melamine-covered shelving, what span can I run? There's no room to use shelving brackets UNDER the shelves. Plus, it would look bad and take up valuable wall space. Therefore, I assume the best solution may be to use brackets attached to the tops of the shelves and to the wall. If I use that method, how to I attach them to the wall? (It's drywall, but they'd be attached to the studs.) I thought about making brackets with dados and putting a runner along the edge of the shelf next to the wall. I'd probably have to put two or three brackets between the walls for strengthening, but those interrupt the flow of the shelves. I could use the metal keyhole hangers in the brackets, but the ones I have are not the easiest to install accurately.
If my explanation is confusing, I'll try to do a Sketchup drawing later today. The question is how to hang 8 feet of shelves in a laundry room without brackets descending below the shelves. I'm up for using shelving board, Melamine, or plywood. The shelves will be painted, hopefully with a paint that's not sticky. All recommendations are welcome.
Henry W
Henry
An 8' shelf will sag with any load - unless 'properly' supported. In this case a full length cleat (flat, 90 deg angles, not a bevel cut French cleat) along the back and sides of the shelf will do wonders for support. The front will still sag under load (you don't state shelf width or types of materials to be supported). Facing a 12" wide shelf with 1.5 inch of hardwood strip, for example, and using a full length cleat on the back edge (and sides) will 'likely' work fine. For paint grade shelving, that's what I would do. The cleats can be screwed in the studs through the drywall and need not be more than 3/4" x 3/4" (or 1x2s, or... whatever you have on hand).
Use an ENAMEL paint rather than 'any old latex' paint in order to avoid stickiness. Talk to a reputable paint dealer about your application to get the right product. If you can spray, a white lacquer would likely work as well.
Henry is right - any 8' shelf like that will sag unless you put brackets every 2-3 feet. (I assume you want to put things like laundry detergent/ clothes irons onto the shelves, not individual sheets of rice paper). You could of course take standard triangular shelf brackets and simply mount them to the top of the shelves and the wall. But, that means the shelves are interrupted every 2-3 feet, and it's not as strong. It also doesn't look great.
Trying to think outside the box - or rather inside the box: What if you built them as floating shelves? If you used half inch plywood and made a torsion-box like structure that's about 2.5" tall in total, it would be very strong. You could simply mount a piece of 2x4 to the wall and slide the shelf over it, then fasten to the 2x4 with screws. But this assumes you have room for such a tall shelf, not sure based on your description.
