After building a couple of full sized pieces in cherry I had a stack of short boards sitting around. Too nice quality to waste. I’ve been wanting to build a chest from a Lynch measured drawing but no place for it. So I decided to go for a half-size version that could be purposed for a jewelry or some other use.
The cherry boards were fat 4/4 that surfaced clean and flat at 7/8. I resawed them to get 1/2 inch case pieces plus 1/4 inch to 5/32 pieces for drawer faces and bottoms.
Resawed case pieces cut to length and stacked after thicknessing. I also stickered the cutoffs after planing them to 1/4 inch.
Here are the drawer webs assembled before assembling the case. I glue up and square the webs before starting to assemble the case. Otherwise too many parts to juggle in a glueup.
To give an idea of size these are the drawer divider stiles for the top two drawers. All the drawer pieces are mortised into the case sides or as here into the drawer blades.
Here is the case sides and drawer webs dry assembled to check fit. The drawer runners are glued to the front drawer rails but dry tenoned into the back rails to accommodate seasonal movement.
Case assembled dry. The bottom dovetails will be covered by top molding on the bracket feet.
This is the applied molding for the top of the case. I shaped it on the edge of a board and then rip it off.
Template for the bracket feet shape an story sticks (left) used to mark out the drawer positions on the case.
Here's where it stands now. Drawers are dry assembled. They will have applied lipped faces made from the thin cutoffs of the case sides. The feet are not attached yet. The case is sitting on blocks so I can adjust the fit of the feet and mark out place for the glue blocks that will attach them to the case
