I'm trying to cut a modern handsaw blade into pieces (to make other tools) but I'm not having good luck using the bimetal recip or 'regular' hacksaw blades I have on hand. The handsaw steel just rapidly wears the teeth right off the cutting tools - even using a bit of cutting oil.
Should I be buying a particular type of hacksaw blade ? BTW, I am using the blades in an air-driven body saw, so heat is a factor I'm sure.
-Mark
-Mark
